Manual song key assignment
I’d like to be able to manually label the assigned key for a song. Sometimes the analysis interprets the key wrong. Obviously no algorithm is perfect, and I’m surprised it works as well as it does. Although it is frustrating not to be able to fix this manually unless I’m overseeing something?
Thank you,
/Jacob
Hi @Kushman, thanks for the suggestion. This has been requested in the past, but I will forward it again to the dev team for consideration.
