Manually set Key info
Hey guys
Just wondering if you could add a feature so that if DJay has analysed the key of a track and come up with the wrong key then you can go and edit it to manually set it onto the correct key?
I’m on iPad Air with WeGo 2.
Love my portable setup :slight_smile: thanks for a great DJing solution.
Lewis
Thank you for your feedback, Lewis!
We’ll have an eye on your idea!
