Map main volume from each deck to slider?
Anyone find a way to midi map the main volume control for each deck? Here are all the parameters that show up for me, when trying to map my slider.
Jog Wheels
  • Scratch
  • Scratch (no touch detection)
  • Jog Seek
  • Pitch Bend
  • Scroll Library
Turntable Controls
  • High EQ
  • Mid EQ
  • Low EQ
  • Gain Tempo
  • Tempo (Relative)
  • Pan
  • Scrub
Looping / Skipping
  • Loop Duration (Rotary)
  • Skip (Rotary)
Effects
  • Filter
  • FX 1 Select
  • FX 1 Parameter
  • FX 1 Wet/Dry
  • FX 2 Select
  • FX 2 Parameter
  • FX 2 Wet/Dry
  • FX 3 Select
  • FX 3 Parameter
  • FX 3 Wet/Dry
  • Key
Neural Mix
  • Neural Mix Filter (Instrumental / Acappella)
Neural Mix (Selected Channels)
  • Neural Mix Volume (1)
  • Neural Mix Volume (2)
  • Neural Mix Volume (3)
  • Neural Mix Volume (4) Neural Mix EQ (1)
  • Neural Mix EQ (2)
  • Neural Mix EQ (3)
  • Neural Mix EQ (4)
Neural Mix (4 Channels)
  • Neural Mix Volume (4ch: Drums)
  • Neural Mix Volume (4ch: Bass)
  • Neural Mix Volume (4ch: Harmonic)
  • Neural Mix Volume (4ch: Vocals)
  • Neural Mix EQ (4ch: Drums)
  • Neural Mix EQ (4ch: Bass)
  • Neural Mix EQ (4ch: Harmonic)
  • Neural Mix EQ (4ch: Vocals)
Neural Mix (3 Channels)
  • Neural Mix Volume (3ch: Drums)
  • Neural Mix Volume (3ch: Harmonic)
  • Neural Mix Volume (3ch: Vocals)
  • Neural Mix EQ (3ch: Drums)
  • Neural Mix EQ (3ch: Harmonic)
  • Neural Mix EQ (3ch: Vocals)
Neural Mix (2 Channels)
  • Neural Mix Volume (2ch. Instrumental)
  • Neural Mix Volume (2ch. Acappella)
  • Neural Mix EQ (2ch. Instrumental)
  • Neural Mix EQ (2ch. Acappella)
You must MIDI map from the “Mixer” Section in order to see Channel 1-4 Volume Levels, not “Deck 1-4” Section.
Ah ha!
Thank you for pointing that out. Wasn’t even looking at that middle column in the mapping menu.
