Map the Looper volume fader to DDJ-FLX4
Is it possible to map the looper volume bar/fader to the FLX4?
Namely to the FLX4 mic level rotary knob as I’d never use that for it’s intended purpose.
thanks
Randy
Pioneer DDJ-FLX4 and DJ Pro AI for Mac
@DJRan yeah, that should be no problem assuming the Mic Level knob on the FLX4 is MIDI mappable. I don’t have a FLX4 so I can’t check. As for the MIDI command, see below. This is on iOS, but I’m pretty sure it’s the same on MacOS.
Also if you’re new to MIDI Mapping in djay, here’s a quick guide:
