Hi!
I use djay on an ipad and for now have been using it with pioneers ddj400 controller. Which is totally fine but i’m really excited about the DVS solution.
And i’m also looking into buying a new mixer / controller to expand my gear / possibilities as i’m often using more than 2 decks.
My first question is:
The mapped mixers for DVS like the denon x1850 and rane mp2015 are 4 channel mixers. Is there a way to use all 4 channels with djay on an ios device?
Perhaps controlling two channels via the turntables and the other two channels by the ipad?
My second question is:
Which mixer / controller would you recommend to get most flexibility regarding connecting more gear? Preferably i would like to have 4 channels and the possibility to connect external efx units and a secondary ipad for other apps (like you can on the pioneer djm 750 mk2)
Thanks for your feedback!
Best regards
Vegar
