Mapping DDJ-WEGO3 with iPhone
I have a DDJ-WEGO3 and an iPhone 12 with latest iOS. Would be cool to get the mapping correct. For instance the EQ which is not working right now, it is mixing it up with Neural. Have got the latest version of Djay Pro (5.3).
How do I go about doing that?
Jonas
Hi @DJ_Boum_Boum,
  1. Have you checked the Pioneer DJ website to confirm you are running the latest WEGO3 firmware?
  2. If you would like to customize the built-in MIDI mapping, please refer to the FAQ linked below: https://help.algoriddim.com/hc/en-us/articles/360016055199-How-do-I-MIDI-map-a-controller-on-djay-for-iOS
  3. If you think there is a problem/issue with the (built-in) MIDI mapping, can you please try to capture a short video of the issue and upload it here? Please note the maximum file size is 200MB, so if your video is larger than that, you’ll need to upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the file here. Thanks!
Thanks so very much! Now everything is working as it should.
Best regards,
Jonas
You’re very welcome @DJ_Boum_Boum. Happy to help!
