Mapping filter on ddj200
Hello,
I want to modify pioneer ddj200 mapping.
I put on a pad button “kill low EQ” but i dont want to kill them all.
How i can map a button with a specific % of High pass filter . For ex 50% .
Hi @Yan,
  1. If you only want to set the EQs or Filter to 50% (the Middle Position), then you could MIDI map it Reset instead of Kill.
  2. If you want to MIDI map this to a value other than 50% this is not currently possible with a button.
