Mapping for Hercules impulse 500
NOTE: Please use the search function above before posting to avoid creating duplicate topics. how do I reset something I mapped on the Hercules impulse 500? I am trying to set the shift keys back to default? Also is there a way to map the effects to the sampler pads?
iPad 10th generation
iOS 18.5
Your question:
Hi @Carla_Spence,
  1. There’s no way to reset or undo something that you have custom MIDI mapped. You can delete the command and remap.
  2. Probably, you best option is to start over with the Hercules Inpulse 500 (built-in) MIDI mapping and make a new edit of it.
  3. Yes, you can MIDI map the Sampler Pads to Instant FX 1-8
