Mapping for Pioneer DDJ-T1
Hello,
Did Algoriddim ever make mapping for DDJ T1?
In an old post it says “not yet” somewhat indicating it was coming.
Thank you
Stefan
Hello @SLMIA, welcome to the forum.
  1. Unfortunately, the Pioneer DDJ T1 is not natively supported on djay Pro AI for Windows: DJ Controllers, DJ Mixers and other DJ Accessories | Algoriddim
  2. Given the age of this controller, I suspect that native support will not be coming.
  3. However, it looks like someone made a custom mapping for it and shared it on the DJ TechTools maps page: DJ TechTools - DDJ T1 Djay 4 deck map
Thank you for the quick response…
These old but good controllers are now available for small money ($200) and its a pity they cannot be used. The mapping you shared may work but perhaps not 100% and its a critical application.
Is there a supported list of HW? I have a budget pioneer and a Hercules 4MX.
Thank you Stefan
@SLMIA you’re welcome.
  1. I shared this list of supported hardware for Windows above in point #1. The hardware is listed at the bottom of the page. Also you can select your Operating System to see the specific hardware supported for each OS. Here’s the list again: DJ Controllers, DJ Mixers and other DJ Accessories | Algoriddim
