Mapping Keyboard shortcuts
Is it possible to map keyboard shortcuts to MIDI commands? To make prepping simple, I want to map the “option+A” and “option+S” shortcuts to two unused buttons on both deck on my Hercules Inpulse T7 controller.
I’ve been looking and don’t see any way to jump around by bar to edit cue points when prepping.
Thanks in advance for any direction on this.
Hi @jakehole, welcome to the Community! Please note that Keyboard Shortcuts and MIDI commands are separate and independent of each other. If you are talking about duplicating the existing keyboard shortcuts for “Option+A (Deck 1 - Reloop/Loop Off)” and “Option+S (Deck 1 - Loop Half)” to free buttons on your hardware, then yes you can do this. The MIDI commands are named the same as the Keyboard Shortcuts.
For more on how to MIDI map on macOS, please refer to this FAQ: https://help.algoriddim.com/hc/en-us/articles/360014911871-How-do-I-MIDI-map-a-controller-on-djay-Pro-for-Mac
