Hello,
I’m mapping my mixdeck express to work with Djay for windows and I’m up to the stage where I’m mapping the midi out. Its proving to be a very tedious process because there is 127 midi out signals and scrolling through then with a very small slider means you have almost zero control. Its hard to see exactly what signal results in what output and then relocating a signal once you find the right one is a pain.
Can you please add a simple button each side of the slider that just goes to the midi signal each side. EG if your on midi signal 3 and you press the button on the left of the slider it goes to midi signal 2 and the one on the right goes to midi signal 3. That way you have a mix of coarse and fine adjustments
