Device model: iPad Pro 11"
Version of operating system: latest
Version of djay: latest
Hardware/controllers used: Mixon 8
Hello again. As you guys may know when I press shift and the Botton shown in the screen shot. It turns on the neural mix levels controlled by the EQ pots. Is there a way to map the button so that when I pressed shift and press the button it stays lit up and I can see that I have the neural mix on.
@Nubium you can enable LED output in the advanced section of the MIDI Mapping. However, because this is mapped to the SHIFT+ layer of the controller, the LED will only illuminate while SHIFT is held down.
