Mapping Nanopad 2 to Djay Pro for Mac
I am trying to map a Korg Nanopad 2 to Djay pro for mac. Buttons are not a problem. But I am trying to map the XY pad to the FX pad of the app. I just cannot figure out how to do it. Thanks!
I tried this as well, but managed to map up/down on the pad as FX Parameter and left/right as FX Wet/Dry. Which is pretty cool.
So far it looks like the NanoPad is a better controller for DJay than Traktors X1. :slight_smile:
(BTW, late reply, as I found this now.)
Thank you Keiko! I am checking the Korg Control Editor. I came to the same conclusion as you.
Hi Gustavo,
It seeems that is not possible. Check out the Korg Kontrol Editor ! The pad has no direct set-up there.
In MIDIPIPE you get an response from the pad with CC1,CC2,CC16.
1+2 are shown in DJAY as Fader/Knob CC16 as Button. I can not find any
command in DJAY that has a general function as x/y pad.
greetings
Heiko
I want to mapping between Korg Nanopad 2 and Djay Pro in Windows system. How can i do this ? I want to control XY effects with Nanopad. Can you help me ?
