Mapping Rotaries on Mixtour Pro
Is there a way to map secondary functions to some of the rotary knobs on the Mixtour Pro? For example, using Shift+High EQ to change tempo, or Shift + Filter, etc. There’s a lot of unused real estate there, but I can’t seem to do it!
  • Reloop MIxtour Pro
  • MacOS 26.01
  • Djay 5.6.2
Hi @ranchnet, unfortunately, the Mixtour Pro does not send separate MIDI commands when holding SHIFT + rotating the EQ knobs or Filter knobs. So, you will not be able to map these to a secondary function.
