Master volume button and screen on features
Please I’m suggesting adding Master volume button and screen always on. Also the bounce feature most times cause music to go out of sync even while you press the sync button it doesn’t return to sync. Another suggestion is creating a function that when two songs are in sync then adding another to the sync would make the song in that particular deck, while the other deck is for the beat. Thank you so much djay team. Your app is so wonderful :blush: :+1:
Hi @Saviour_Peter, thanks for the suggestions. However, it’s best to create a single topic for each suggestion so other users can upvote the ideas and we can track them properly. Please also share more details about each suggestion and include screenshots or screen recordings where possible so I can clearly communicate your ideas to the dev team. Thanks!
