I run Djay Pro along with Ableton. Djay has higher volume than Ableton. But when I lower the master volume of Djay to balace with Ableton. This lower my overall laptop volume. Could it be possible to separate the master volume control from the laptop volume? Currently I can only set the individual deck volume to half to balance with other software. I want to set the proper ratio between softwares.
You can use the “Master Volume” control to adjust the djay Pro Output only:
