match error when using spotify
sat down last night to use djay PRO on Macbook pro when going into the match function its giving me an error - Request failed: internal server error (500) try again. i have logged out of spotify and logged in, restarted the app and machine but no luck, all other aspects of spotify is working its only the match function. any help would be greatly appreciated. thx
Hi gerard mcmullan,
thank you for your post. We are sorry to hear about your Match issue.
Are you able to reproduce this issue?
If yes, can you tell us in detail how?
so the Match function is not working at all at no time?
Not sure what u mean Lukas it’s still not working?
I get the same. As soon as I play a song i get gateway failure (504).
actually its says, gateway timed out (504)
I get the same problem. it says gateway timed out (504)
