Match Function not searching in Local Files though preselected
IOS iPad iPhone
Djay 5.3
Summary of the issue:
Though preselected, Match function during track loading does not search in local music but shows matching tracks from Apple Music.
How to reproduce the issue:
Load new track, choose “Match”, select “Source:Local Music”. Randomly matching results from Apple Music are displayed, sometimes matching results from “Local Music “ are displayed
Hi @turbopussy, sorry for the delayed reply. Please note tha Match is not supported in Local Music on iOS. Most likely it is using Apple Music Streaming as djay will pick a “fallback” source or the last source used that supports Match.
Thanks @Slak_Jaw . Though I do not understand why searching for matches in Local Files is not implemented (and it appears a least buggy for the reason that “Local Files” can be selected but are not displaying results), here is a little workaround:
I select “Sessions” as a source for matches and as I play 99,9% local files only, it displays matches out of the previous sessions (however, not my whole local file pool, but this is a matter of time :wink:
Thanks for sharing your workaround @turbopussy.
