When the ‘Match’ sidebar is set to pull from ‘Music’, the list of matches is limited to (presumably the best) 24 tracks. This behavior is consistent with the description in the manual. However, when the sidebar is set to pull from ‘My Collection’, the list of matches contains hundreds of entries in every key.
I have my key display set to ‘Numerical (1A / 1B)’, which I assume is the equivalent of the Camelot Wheel used in Mixed In Key. The description of the Camelot Wheel states that appealing mixes can be made to the same key number (example, 2B), adjacent key numbers on the same key wheel (1B, 3B), or to the same key number on the other wheel (2A). However, the match list seems to not follow this. An example is that for a 2B track, the matches are listed for 2B and 7A tracks, despite my library containing plenty of 1B, 3B, and 2A tracks of the same BPM range and energy level. Is DJ Pro AI using a different numerical matching method? If so, where can I find a description of the theory for matches?
Where are these matched tracks being fetched from? Tidal, iTunes, Locally stored, etc?
What are some of the songs in question which we can further test to see if this is a universal issue?
Have you found that this issue was resolved in the latest version of djay?
Fetched from locally stored tracks (My Collection and/or Apple Music categories)
All songs. Note that my question is about the key match suggestions, not key display. I am questioning why the suggested tracks are not of the correct numerical format keys as defined by the Camelot key system. Please review my original description, and view the above video for documentation of the issue.
The problem persists in the latest version of DJay v4.1.10
Looking forward to your responses and resolution. If you need additional information please let me know.
