Matching Tracks sometimes Empty
I’ve noticed an issue with the side panel in the matching tracks section. When going back and forth in the app, the list sometimes appears empty, even though there are enough tracks to display. Additionally, it can take a long time for the list to load. Not in this video, but it also seems to get slower over time.
I realize this might be due to the app scanning the entire iTunes library, which has already been discussed here. Many users, myself included, would prefer to narrow down this selection to only the relevant DJ playlists from iTunes (or other sources). I think the speed could improve significantly if we could limit the search to specific playlists.
For a better idea, please check out my video example here.
Thanks for considering this!
  • Device: MacBook Pro (16", 2019)
  • Operating system: Apple Os / Sanoma 14.4.1.
  • Djay version: Djay Pro 5.2.1
  • Hardware/controllers used: Reloop Mixon Pro 8**
Btw; the right deck in this demo video was always filled because it always had Related tracks’ to show.
Hi @DJ_Big_Blender,
Thanks for sharing this behavior with us!
We are still reviewing this internally and will reach back out very soon with further information.
Please let us know if there have been any other updates since your original post. Thanks!
Great to hear that you are looking into this!
In the meantime: when I could help bij sending a logfile or so on…I would do glad to do so.
And coincidentally or not; in the first video the ‘Empty Matchings’ are all in deck on
And also I had the software already “Running for a while”.
