Hi everyone. I took a long time to program and map my mcx8000 and was very happy with the results. I was asked to play an event yesterday. Plugged everything in and my fx were just not maped correctly.
Is there something incorrect I am doing?
Also the pitch fader on both decks are not very responsive.
I have to literally move them to the maximum and then back to the centre to get the track back to original BPM.
Did you save the Map when you created it?
If so, it should still be there…
In Settings/Midi Devices
Select the default Mcx8000 Midi Device connected and then it should also have the map that you created under it.
