Mic audio FX / DJ controller with USB audio in
Just bought a DDJ400 and I’m gutted to realise that mic audio doesn’t actually go the the connected device via USB! So … no mic FX possible. I can probably work around this with an extra interface for now, but for future reference - are there controllers that support this?
Also: Can Djay add FX to a mic input?
Hello @jomtones ,
Thank you for posting this here in the Algoriddim Community.
Regarding the possibility of adding FX to a mic input directly on djay, this option is currently not available. In general, the best solution would be - as you already mentioned - work around this with an extra interface.
Cheers!
