I’m using Djay pro with DDJ-SB2
I plugged mic to SB2 but i can’t control mic on djay software.
I can’t see the level of the mic and can’t control echo and pitch.
Also I can hear the mic from the speakers but can’t record the mic from the software.
due to the hardware limitations of the controller recording through the controller is not possible.
I would recommend getting an adapter to use the Mac mic input for recording or a mic in to USB adapter.
