Microphone Not Working
I’m using Djay pro with DDJ-SB2
I plugged mic to SB2 but i can’t control mic on djay software.
I can’t see the level of the mic and can’t control echo and pitch.
Also I can hear the mic from the speakers but can’t record the mic from the software.
Need help about that.
Thanks.
Hi Türker Akman,
thank you for contacting us.
We are sorry that we did not answer in time.
As you already figured out, the SB2 is sending the Microphone input straight to the master.
Hi Perre,
djay for Mac is supporting the input of externally connected microphones. If a controller is not sending back a Mic signal via Midi, that means the controller is not supporting this and using the Master out as microphone output.
Hi Eros Ayala,
this sounds more like an hardware problem. Please contact Pioneer for help.
Cheers,Lukas E.
This is due to the hardware of the controllers. They root the Microphone to their Master Output, djay can not see them at all.
My mic level on the sb2 is not working, if I turn it up just a little, it easily grabs feedback even if the speakers aren’t near the mic. Pls help
I figured out the problem.
DDJ-SB2 is not sending mic signal from USB output.
The problem is not about the software.
But Algoriddim might have helped about this problem :wink:
Why can’t you record mic with Wego3… absolutely makes no sense.
i have a ddj sb2 and my mic is not working i have sound comping out of bluetooth
and I’m using a mac on djay software
Is it a settings file or mapping issue?
