Are you using the latest firmware (v5039) from Reloop for the Mixon 8 Pro (Reloop Mixon 8 Pro - Reloop)?
YES
Are you using the built-in MIDI Mapping or a customized one?
Customized one
Can you please share a screenshot of the MIDI Mapping Settings for this button?
I attach a screenshot although not sure it helps really so I attach my midi map.
Many thanks in advance for any help that you could provide.
Also, it’s a bit unclear from your description of the problem what is happening. To help clarify things, can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Hi Thanks for your post.
No not the same behaviour with Builtin MIDI mapping.
In a nutshell 2 buttons are going to the same Note C#1 command independently of whatever value I put. Other buttons are going each of them to a different Note: C#1 command.
I link a short video recording hoping it makes understand my issue:
Thanks for the video @Djay_Fleg. This looks like a hardware or firmware issue. I recommend that you try installing the latest firmware from Reloop twice. I experience some odd MIDI behavior on my Mixon 8 until I installed the firmware a second time. If this doesn’t solve the issue, then you should contact Reloop Support regarding this hardware/firmware issue.
