MIDI command for Activate Cue Loop
Recently DJAY added the ability to save a cue point as a loop, which is fantastic.
The UI has a loop icon which can activate the the loop. Is it possible to midi map activate cue loop?
I see Saved Loop Activate X, but this is for the Saved loops tab.
Hi @rishi, thanks for the question. There is no MIDI command for this.
@Slak_Jaw Any chance of adding this to feature suggestions?
Traktor has an Activate Loop button that is midi mappable. It activates the next loop ahead of the playhead. I like this solution as the current solution for saved loops requires a midi mapping for each saved loop. The Traktor approach only requires 1 button and works for all saved CueLoops.
Also, the UI element for activating the loop is too small. I keep triggering the loop when I try to activate the loop.
Hi @rishi, I’ve changed your topic from a Question to a Suggestion. You can now Vote above. I’ll also share this with the devs for consideration. Thanks!
This is an excellent recommendation. I keep triggering the loop, too. That’s really a mix killer because we aren’t trying to jump to that loop, we were just trying to activate it before we get to it.
Being able to midi map a button to activate the loop would be fantastic. I could use the silly sampler banks or loop slicer crap the nobody uses.
Thanks for the additional input @DJ_Chris_Argueta
+1 I would also like to see this function in the future
Thanks for the vote @VincentSonore
Nice. Love this.
Djay pro has currently removed cue loops, I have a feature request to bring them back in case people want to vote that
Thanks for linking to your other topic @Ben_Cislaghi
Of course :blush: I just reeeealllly want them back hihihi :slight_smile:
I hear you loud and clear
Hi @Slak_Jaw any updates on this as the festival season begins ? Or any tested workaround ?
Hi @Ben_Cislaghi, we don’t have any updates to share.
