MIDI Command for "Analyze Songs"
Can I please request a mapping for “Analyse file”
its quicker for me to do this on the fly while playing live,
most files on DJay Pro after analyse all files in folder, does not analyse properly, so when I do come across a file that hasnt been analysed properly,
if I had a mapping for analyse file,
I would be able to do this quickly on the fly instead of right clicking then analyse file, thank you.
Thanks for the suggestion @eecy_cee. I will pass this onto the dev team for consideration. Please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Much Appreciated as always Slak_Jaw :folded_hands:t3::folded_hands:t3:
You’re welcome @eecy_cee
@eecy_cee do you get a different result when you analyse a track manually like that? :thinking:
Yes, I do get a different result, on my side.
Thank you for voting I appreciate it🙏🏼
Interesting!
You’d imagine they both do the same thing :thinking:
I found an easter egg by accident,
when you analyze all in a crate, DJay Pro does analyze all files,
but the easter egg is, some of those tracks the grid is off, if you re-analyze that song that the grid is off, the grid is automatically fixed, just reload the song and you will see the grids are fixed,
this doesnt happen to all tracks but it does work with a majority of tracks that are re-analysed.
Please vote up top thanks.
Regardless of how you analyze a song, the outcome should always be the same.
That sounds more like a bug :thinking:
have you tried it out? next time you come across a song that the grids are out, give it a try :slight_smile:
