I was surprised not to be able to assign the manual /instant effect. Very annoying to have to press the button via laptop when I like to take advantage of all the great effects. Should be no big deal to do.
I’m not sure I understand your problem exactly. You can assign both the manual and the Instant FX via midi.
Perhaps you can specify this in more detail?
Hi @Jason_Jaso, we have a comprehensive set of MIDI commands for both Manual and Instant FX. Please ensure that you have the Target set to Deck 1, 2, 3, or 4 then scroll down to the FX sections to see the available commands. Please note the available commands will differ depending on whether you are mapping a button, knob or fader. I hope that helps!
Here is a small sample of available commands:
I wanted to be able to toggle between the manual and instant efx, instead of having to use the mouse to see one or the other visually. So I was hoping to set it to a MIDI key to go back and forth quickly as I use both.
Ah, okay. Now I understand. You want to toggle between the different User Interface Display Modes. Got it! I’ll share this with the dev team for consideration. In the meantime, please use the Vote button at the top left. Thanks!
With the Mixtour Pro, selecting a pad mode twice will display the corresponding elements on the screen. Perhaps it would be possible to make this possible in principle and not just limited to certain controllers.
Yes, something that works like the the button on the. Mixon 8 that can toggle EQ/STems
