MIDI Commands for Denon Prime Go
  • Device model (e.g. 2024 iPad Air 5th Gen):
  • Version of operating system IOS):
  • Version of djay ( 5.3):
  • Hardware/controllers used (Denon Prime Go):
On the Denon Prime Go, There are 5 buttons that receive a midi command in the Midi Scope App but can’t be mapped in Djay.
I have a midi map that was created by Dj Geronimo I believe,
In that map the buttons can be mapped to commands but in native Djay Pro map, the buttons show no command.
The 5 buttons are,
FX Select On,
FX Assign 1 & 2
Mic 1 On / Off button
Mic 2 On / Off button
Is there any way to get these buttons to work?
Hi @maurizio_T, I suspect these buttons have been locked out intentionally to ensure proper functionality with djay. I’ll reach out to our hardware team though to see if these can be enabled for MIDI use in djay or not. I’ll report back when I have news.
Thanks again Slak,
I can’t see why they would be as they don’t serve any function..
Maybe the Mic1 and Mic 2 on/off buttons but the other buttons are to switch FX and in reality are just Midi commands.
I also noticed that the Shift button doesn’t register as a Midi command but thankfully it acts like the Shift command
You’re welcome @maurizio_T
Hi again @maurizio_T, here’s the response from engineering:
  1. FX Assign 1/2/ON are handled internally and can not be MIDI mapped.
  2. Mic 1/2 ON buttons are mappable, they are highlighted in the screenshot, they just don’t auto select when you push them.
