Mac Book Pro, Mac OSX Sequoia 15.2
DDJ-SX2 Controller
As shown in the picture, I cant find these buttons on the mapping list to map them,
I want this to be able to do on the fly grid adjustment, makes it so much faster for me while playing live. at the moment I can only do this on my Mac track pad. Thanks.
              Hi @eecy_cee, currently there are no MIDI commands for Grid Adjust Left and Right. See below for the current list of available BPM/GRID EDIT MIDI commands. I hope that helps!
              Yer Thanks Slak_Jaw, I realised that, I was Hoping that Algoridem can add it later if thats possible thanks bro.
              You’re welcome @eecy_cee. I have already suggestion shared this with the dev team.
              I appreciate you, Thank You Slak_Jaw.
              Thanks @eecy_cee. You’re welcome.
              I use that feature in the software a lot whilst beat mapping with sync button, you can nudge a track forward/backwards without stopping sync. Quite handy. Midi mapping to a hardware controller would be a great option.
              Hi Andrew its a great tool for making light adjustments to grids live, Which is what I do on a regular, my quick workaround is to use a wireless mouse on top of my mac wrist rest,
I can use the Mac track pad but it takes a while to do this, I find a mouse is much quicker response.
if this was mappable then it will be much quicker.
              I’ve changed this topic from a Question to a Suggestion so everyone can upvote it at the top left. Thanks!
              Thanks Slak_Jaw thats a great Idea:)
              This would be a fantastic addition to the list of MIDI commands.
As someone without sight, using the trackpad/mouse or other visual methods is very cumbersome, so having the ability to map this function to my controller would be brilliant, so plus one from me.
              Hi actsofblindness
thanks for agreeing with my request make sure you vote at the top of this thread I apprecate it.
              Thank You to Slak_Jaw and the DJay Pro Algoriddem Dev Team for putting my requested feature into the 5.4.2 update, I really do appreciate this update
- Added MIDI mapping actions to shift beat grid left/right
This will enable me to really make the slightest grid adjustment on the fly.
