Would like to suggest an important function that needs to be included in Djay Pro as soon as possible it’s about the sampler pack i think we should be able to map the sampler pack to give access to navigate through each sample pack on the controller without using the trackpad to select on MacBook or any other djay pro supported device thanks
Hi @Temitope_Oyebode, just to clarify, you are looking for MIDI commands to cycle through and select the available Sample Packs?
actually, not a bad idea. push key ‘x’ to select sample pack ‘y’, one is for effects, one is for sfx like applauds, etc. would be nice to have such a thing, yes
Yes that right and its what I’m talking about
Thanks for confirming @Temitope_Oyebode. I’ve passed this onto the dev team for consideration.
