Do you have a list with all possible functions that can be controlled via MIDI ?
b.r.
Heiko
b.r.
Heiko
sure, but it is not so nice to work with.
I always must go back to the editor software(OSC ) and label the button/fader/pad
with the correct “definition” like “skip” or whatever.
That takes a lot of time.
No, I’m sorry, there’s no list of all possible midi configurations. However, you can see them in the Configuration window once you have connected a midi device.
If you want to make sure the correct midi control is being mapped, just hit the control on your controller. djay Pro will automatically mark the midi control. Also use the advanced Configurations to assign the midi control correctly.
