PC
Windows 11
Ver 5.5
ISSUE: Target Selection does not update on screen until user scrolls item out and back in to view
DETAILED STEPS TO REPRODUCE:
- Open MIDI Config
2)Press button on MIDI Mixer - Select Any Target in drop down menu and press return
- Note target does not update
- Use mouse wheel to scroll list up TWO clicks so that the line leaves the bottom of the window
- Scroll back up so that line reappears.
- Note that target has now updated with the correct selected value
C) EXPECTED RESULTS:
Target should correctly update without having to scroll up and down
D) ACTUAL RESULTS:
See video
Also note that it must be two clicks. Scrolling only one line off the screen does not change the value.
