Thanks to my previous question I’ve discovered the sample sequencer which is great. However, I can’t seem to find any way of starting and stopping it via midi (or clearing it). I’ve checked the spreadsheet and there’s nothing in there.
Is this just missing or is it hidden somewhere I can’t find it? I’m really trying to avoid using the mouse wherever I can these days.
And a follow up - the feature which allows you to apply looping and effects just to one area of the neural mix - are those midi controllable?
If not, it’d be super helpful if they were added to the menu - I have found a hack with applescript to get around it but it only applies if they’re in the menu.
For your first question… are you talking about the record/clear controls a the bottom of the sampler section? Those don’t have MIDI commands currently.
