Good day!
Doesn’t look like it is possible to assign a midi control to toggle pre-queing on/off.
Am I missing something?
Thanks & cheers, Bart.
Good day!
@Brainbox the MIDI command you’re looking for is called “Deck 1: Monitor Active”. It’s found in the Mixer section of MIDI learn. Attached image is from iPad, but I’m pretty sure it’s the same on MacOS. Obviously you’ll want to use Deck 2: Monitor Active for your second deck pre-cueing.
