midi controller and djay pro on iOS
I am struggling to connect a midi controller to my iPad 2 (ios 9.3.5) running Djay Pro 1.0.25
Using a Vestax VCM-100 (powered with adaptor)
Plugged in via camera connection adaptor (Apple A1358)
Djay recognises a device is connected, but says not compatible, although on webpage it is listed as a natively supported controller.
Used a midi program to check (midi wrench) and midi signals exist
Tried connecting via a  powered USB hub too.
Any ideas?!
Hi Adam,
The Vestax VCM 100 is supported by djay for iOS.
Unfortunately, there was no mapping introduced for djay Pro back then.
