Is it possible to use a midi controller for a sample board. I recently downloaded beatsurfing the app for the ipad so I could draw my own midi controller. Is it possible that I would be able to use this midi controller for my samples instead of going into that separate window all the time?
Hi Jeffrey,
I’m not quite sure about the MIDI controller you’re referring to, but yes, generally speaking you can assign buttons to play the samples.
