PC
Windows 11
Ver 5.5
ISSUE: The window scroll bar on the right hand side of the Action drop down menu does not work as intended.
DETAILED STEPS TO REPRODUCE:
- Open MIDI Config
2)Press button on MIDI Mixer - Select Drop Down Menu under Action to bring up full list avaibale acrions.
4)Move cursor over windows scroll bar - Hold down Left Mouse button
- Drag Mouse downwards to scroll down thrrough list
C) EXPECTED RESULTS:
Scroll Bar functionality should work exactly as all windows scroll bars do and as expected.
D) ACTUAL RESULTS:
- Observe that the mouse does not grab the scroll bar and cannot quickly navigate through list
- To access actions at bottom of list, the user can either use the mouse wheel, which only scrolls through at a very slow rate or click an hold on an action near the bottom of the list and drag the list upwards.
