midi edit bug when multi-select
If I use shift to select multiple items in the midi controller editor (using the arrow key to select multiple while holding down shift) then delete those items, there is some strange behavior when making another multi-select… it’s like there is a second “cursor” further down the list that moves/grows/shrinks in step with the main selection.
see screen recording:
