MIDI learn Button , like in Ableton
Hey,
Have you ever used MIDI in Ableton. It’s the best handling I’ve ever had.
Just press the Learn Button on top of the Programm. Move the MIDI Stuff on your Controller = done. It’s super easy and you don’t need to search through the whole midi options to find the correct button in the app.
For further settings you can keep your midi options as they are. I like them .
But just to get and find the right button in the midi settings . It always takes a while to find the correct one. Would be all gone if we have a (Midi)-Learn button like in Ableton.
Thanks for the suggestion @riotmode. I have forwarded this to the dev team for consideration.
