DJPro for iPad work with Hercules MK4?
If helpful to somebody, I got my Djay Pro working on my iPad Pro with my Numark Mixtrack Pro 3.
Mapping file is available here: https://maps.djtechtools.com/mappingsā¦
And I used the procedure described by Darren a few posts above to upload file to the iPad, Thanks Darren!.
Hey Kristian, would you be able to assist me configuring my Pioneer S9 mixer and CDJ 900 with DJAY Pro? I was previously using pulselocker with Serato but they are no longer integrated as of Nov 10th. Can you kindly help me out? With the following?
- Mapping
- I have CDJ 800 and CDJ 900 however 800ās are not supported by DJay pro. Can you help me configure one CDJ 900 to work with DJay pro. I would appreciate it. You can also email me at gqhustle2@gmail.com.
Thank you.
Check OSCvid or you can use it in conjunction with TouchOSC
Your best bet itās to customize it in the desktop version then export the mapping to your iPad using iTunes sync
youāre a genuis Tank Jones, thanks man! i tried your tutorial with a numark party mix and ipad (5th generation 2017) and it works! using djay LE, the free app.
In iTunes. Connect your iPad and go to āAppsā. In Djay 2 or Djay Pro you add the midi mapping file in the documents of the app.
Frist download the midi mapping file on your pc.
hi nice trick !! is still working ?
Hi ! DDj SB2 work with Darrenās trick ?
Thanks !
