You can try using the Shift feature for this: map one button to General > Controller Shift key, and then press the shift button on the controller while pressing the cue button to get a second mapping for the cue button. You can then e.g. assign the non-shift mapping to “Cue 1 / In” and the shift mapping to “Clear Cue 1”.
You can enable MIDI Out for LEDs by opening the “Advanced Options” panel on the bottom of the MIDI mapping window, and checking the “MIDI Out” checkbox.
If you mean at the end of the list, this is the current behavior but it’s something we’re thinking about changing in the future.
Sorry to pick up an old topic but I dont think this is quite answered.
#3 there about the scrolling. What I think Cedric is saying is once you scroll the rotary once, it continues to scroll all the way to the list end. Same with scrolling up. How can we map it to where one click of the scroll wheel moves down one track in the library selection?
