MIDI map 2 Decks on Xone K2?
So I’ve read the previous posts on the K2 (and I know it’s not natively supported), but I don’t think I’ve found anyone talking about this. I recently bought a K2 and successfully midi mapped it, but only for one deck. It says that it has 4 layers, but I can’t seem to find out how to map it so I can switch between decks on only one K2. Is it even possible?
Thanks in advance.
Your question:
Hi @DJ_NTU, welcome to the Community! I don’t have access to this controller, but I believe it has dedicated buttons to switch between the 4 layers. So you should be able to switch it to Layer 2 then do all the Deck 2 mappings while on that layer. Assuming it works like most multi-layer MIDI controllers, it should send separate MIDI commands for each button on each layer. So, essentially duplicate what you did on Layer 1 for Deck 1 on Layer 2 for Deck 2.
Okay. Thanks for the reply.
Is there anyone who has done it before?
You’re welcome @DJ_NTU. You might find a mapping on the DJ TechTools MIDI Mapping page:
