MIDI map Bounce Loop Neural Mix assignment
I’d love an option to midi map these assignment buttons for the stems for the bounce loops. My vision for the bounce loop pad tab is, top four pads are the stem assignments, and bottom four pads are the bounce loops. I hope that makes sense, thanks!
Hi @djmikelujan, thanks for the suggestion! Good idea. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
djay 5.5 Release Notes:
  • Added new MIDI actions: “Toggle Cue Point Range” and bounce-loop routing
Yes! Thank you so much
You’re welcome @djmikelujan
