I’ve been messing with this for a few days so thought I’d share in case it might be helpful to someone else. Basically, I looked at Serato and tried to copy some of the functionality from there that comes working out of the box, mainly stems and stems FX for me.
You’ll have to consult the manual for nuts and bolts on mapping and make sure to backup your file if you’ve already made changes or just open this one to see the how and then go back to your file (or vice versa).
Here’s what I mapped:
- Removed looper (kept going into it by accident) - Mapped an additional Sample bank to Sample double press (instead of looper) and added new samples to it
- Remapped Stems pads button to correct order, so pads 1-4 to: Vocal, Melody, Bass, Drums
- Remapped Stems pads FX, pads 5-8 to: Echo out 1/2, Echo out 3/4, Juggler, Landing (these FX are in djay’s software).
- Mapped Acapella stem button to FX 5. Duplicated the row in the midi map and routed to FX 5 (this FX is in djay’s software). Delete this line if processing is not preferred for the Acapella standalone stem.
- Mapped beat jump to Secondary Performance Pad Button 2 (S. banks are for Serato and not usable in djay). Buttons 1-3 jumps forward 8, 16 and 32 beats. Button 4 jumps back 16 beats.
- Mapped both key locks to “Add to queue”
Note that Stems are processed through the software, so uses the FX found in djay and has nothing to do with the HW/SW found in the mixer section of the board. Therefore changes to 3 and 4 above must be done in the software. Image in zip.
