MIDI map waveform zoom?
Your question:
Is it possible to midi map zoom in/out of the waveforms? Can’t seem to find the command if it’s there :confused:
Hi @Ralfi711, yes this is possible. Simply set the Target to General and the Action to the options shown below:
Omg you’re awesome.
Thank you.
You’re welcome @Ralfi711. Happy to help. Thanks for the positive feedback!
Any chance to make it a rotary option too? I’d love to use a shift function on my browse knob to adjust this.
These MIDI functions do not support rotary controls.
I noticed that too. But it would make so much sense. Rotate left for zooming out, and rotate right for zooming in. This would enable smooth, more intuitive zooming without clicking different buttons for zooming. May you change this question in a suggestion @Slak_Jaw, please?
Hi @JurGroove, see the linked topic below:
