Hi I just purchased Djay to use with my Pioneer Wego, For the most part I am very satisfied and I just have a few questions. To start how can I change the jog dial on the Wego/Djay so that the top platter is pitch bend and not scratch or seek? I tried changing the midi settings but I only found the ability to change from scratch to seek.
The other question I have is related to the auto BPM settings. I noticed that Djay changed the BPM on one of my tracks incorrectly. So my question is how can I change the BPM back to the correct speed?
So I did what you suggested with the midi setting and it didn’t change the jog dial. As far as the disabling BPM Auto-Sync I did that also but the song in my library still indicates the wrong BPM speed.
Hmmm I really wanted to stop using Virtual DJ and just use Djay but for now it is just not quite ready for prime time perhaps some time in the future I can make the switch.
