Hello,
I use Faderfox Micromoduls 2gen controllers, which are MIDI only, so I use a tiny USB MIDI interface to link my Mac and the controllers.
I made a MIDI mapping which is perfect for me to control the DJ Pro 2 app, but sometimes I must change the MIDI interface : same controllers, same Mac, same Djay app, but a different MIDI inerface.
Am I oblige to redo all the MIDI mapping with the other interface, or is there a way to use the mapping of the first one ?
I tried to launch DJay Pro via the former xxx.djayMidiMapping, but it doesn’t work.
Any suggestion ?
Thanks in advance,
DdR
- Device model : MacBook Air 1,7 GHz Intel Core i7 + 8 Go 1600 MHz DDR3
- Version of operating system : MacOS 10.13.6
- Version of djay : 2.2.9
- Hardware/controllers used : Faderfox Micromoduls LC2+LD2+LX2 + Esi Midimate eX or CME U2 MIDI
