MIDI Mapping Brake command
MacBook Air M1, 2020
macOS Sonoma 14.3.1
djay Pro 5.1.2 (sometimes you write it “PRO”)
Pioneer DDJ-FLX4
searched for the brake-command (cmd+propeller+1) in the MIDI-mapping, but could not find it. May someone can help. Thanks.
Greetz Chris
Hi @Chq, you have a couple of options:
  1. You can MIDI Map the Brake Transition FX when setting the Target to Deck 1/2/3/4.
  2. Also you can change the PLAY/PAUSE Stop Time to achieve a similar result whenever you press Play/Pause on a deck.
