I’m looking for the (un)official midi mapping for my Pioneer DDJ Wego 4 at Djay Pro for Mac OSX.
Where can i download this?
PS. I have also made a support ticket by Pioneer, because normally you can download Midi Mappings from their Download section: http://www.pioneerdj.com/en/support/s…
is there a way to make midi mapping (no necessarily on ddj wego 4) on djay pro for ipad? (i am using the beatpad 2 and made the mapping on day pro for mac already).
the WeGo4 is mappable with djay Pro for the Mac, but the native support is not yet implemented. Please be assured that the native mapping is coming with the next update soon.
You can share and exchange your custom MIDI mappings with other djay users by sending the respective mapping file:
To share a mapping file:
Select “Edit Configurations…” from the “MIDI Configuration” menu at the top of the MIDI configuration window.
Select the configuration you want to share from the list.
Select “Show in Finder” from the “Options” menu.
From there, you can e.g. send the mapping file via email or save it on a USB stick.
To install a mapping file, simply double-click the file in the Finder.
I like to use my DDJ Wego 4 at New Years eve fully functional with DJay Pro. I hope that the big update is coming soon…the last update was version 1.3.1. Last updated at 30 april 2016…i can see in the Apple Appstore.
With the paid apps for iPhone/iPad/Android (not Pro version, not yet checked) everything is working as it should.
But with the best version of Djay (Pro for Mac), it is not working as it should.
I’ve just hooked up my DDJ WeGo4 for the first time and trying it with both Djay2 and Djay pro on iPad. Using standard USB to iPad cable. Master volume and headphones level are the only items working on the controller. Am I doing something basic wrong or would iPad to square USB cable be what’s needed?
Thanks for any troubleshooting advice!
